Cabin Light Replacement Signature 310
hirsch57
I have a 2007 Sig 310 and after 15 years, a bulb went out in one of the ceiling cabin lights. How do I get atthe bulb? There seems to be no screws to take the flange off to access the bulb. Do they pry off?
Thanks
tpenfield
How many Chaparral owners does it take to screw in a light bulb . . . j/k :ROFLMAO:
See if you can get the flange of the light fixture to turn about 1/8 of a turn (can't remember which way though) The flange should release and you will have access to the bulb. If you merely pry the flange off, you will break it.
Now might be a good time to replace with LED of the same bulb type. My Formula 330 had 10 watt halogen ceiling lights and they would get hot . . . too hot for my concerns. Switched to LED.
