Cable Lube
edcourter
Should you lube a plastic lined control cable, If so with what? Many manufactures say, BUY a new one please.
GA_Boater
Experience says buy a new one. If it needs lube, it needs replaced. You may get a little extra time, but the chances of letting you down are greatly increased.
If you think it needs lube, the cable has worn the the sheath somewhere. Spend the $35 and replace it
Fed
You're supposed to lube the as rod with white lithium grease.
