Cabrio 330 Fuel Tanks
Galdy21
I have a 2000 Larson Cabrio 330 that I seem to have a fuel leak in the area of the starboard side gas tank. Does anyone know how to get full access or has anyone ever removed a tank from this model boat? I also need to change out the sender for the port side so any info would be appreciated!
Howdy
Your limiting the amount of folks that will comment listing in the Larson section but do understand why. The tank in question is in a Larson boat and look for someone that has done it. That said, if you post some pics (third party site for now) we might be able to figure it out.
The sender is easy enough, just remove wires and holding screws, then replace with same length and ohm valve (should be 240 to 33 ohms).
