calibrate weber carb on 4.3 vortec
Danny Mc
Mercruiser -. I have a 2001 4.3 vortec eng with Weber 4bbl/adapter plate on Edel 2114 intake. I am using a 96 4whd vortec cam. This is in a 206 regal valante/21p alum prop. The 4bbl Weber carb was on the original 93 4.3 eng. I read in the posts and got the #1485 calibration kit to change the metering rods to enrichen the fuel mixture, but do I change the primary or secondary metering rods,. The jets seem to be the same as already there. I think they meant the secondary rods but not sure. If I need to go to diff size rods, please advise. Thanks D Mc
zbnutcase
Re: calibrate weber carb on 4.3 vortec
The Weber carbs dont have secondary metering rods.
Danny Mc
OK heres my sign. I had understood that if the carb had Torx hd screws in the lid it was a Weber (wrong) it is a Quadrajet . I still need to know which metering rods to change, pri or sec. The Merc manual says it already has .096 jets in it. Thanks, D Mc
Alpheus
If its a quadrajet and its working just leave it alone.
Danny Mc
I'm trying to follow the suggestions from ones who have done this change over, and needed to enrichen the fuel mix. I was not just looking for something to do. Thanks for your suggestions.
