I just replaced the coils on my old 7.5 hp motor thanks to some suggestions from a few weeks back. The motor definitely runs better. I had it running well, but had a hard time getting the motor to wind out a bit. even at full throttle it wasn't doing much. I started adjusting the lean/rich fuel mixture, but not sure where it should be. What is the proper procedure to calibrate the knobs?? I can loosen the but that hold the shaft to the carb, but just don't know where to tighten.... Also the motor seems to get a bit hot after a while. I think it is running rich due to my bucket of water getting rather black and sooty looking. Not sure if this is normal. It looks pretty bad in there...
Thanks for any help...
