I have posted and listend and tried to fix from the responses. I have a 87 200hp johnson vro engine. I have just rebuilt the carbs today, ran all new fuel lines put in new omc fuel filters. I also put in this week a new flywheel because magnets had been broken, replaced 2 new power packs, new shift interrupt switch and all new spark plugs and wires. I also put in a new oil pressure sending unit for the vro pump. When I run the boat out of the water on the muffs it starts first shot and idles great. I built a tank to put the engine in and in the tank it runs at 1000-1100 rpms and shifts forward and reverse great it also starts up first shot and the interrupt switch drops the idle perfectly. The problem I have is it will not start in salt water and when I do get it started it stalls almost right away. The rpms run about 800 it seems like it does not want to get the fuel. Trying to go forward or reverse will stall the engine. My questions are what else can it be and also how high should the rpms run from the salt to fresh water.<br /> Any help would be greatly appreciated.
