basbalj288
- Joined
- Jul 17, 2009
- 88
I just bought a 76 johnson 85 hp and can't get full WOT and noticed that the ignition advance pin, ( I guess that's what it's called ) about an inch below the fly wheel (runs parallel to the ground) that can be screwed in or out to control the firing and timing of the motor at WOT (I've been told), had been tampered with and broken off at the tip. Since I've adjusted all the other components such as the throttle and carbs, I'm assuming this is the last thing that could be wrong. SOOO if anybody knows where that pin is supposed to be screwed in to, like how far is it supposed to be screwed in, that would be a HUGE help. I've read the manual and can't seem to find it in there. From reading around on this forum I know that pin is not supposed to be messed with because it will throw off the timing but in this case, I need to know exactly where to set it to so that it will help me. I have a trip planned for Saturday and desparately need to figure this out on my own bec/ shops are backed up. So with you alls help that would be great.
If you have that motor and it runs good just let me know where your's is set too and that would be a big help.
Thanks guys! You always are a HUGE help
Matt D.
Matt D.
