With the volume of information you've given all of us on this subject, with literally dozens of posts and graphics as well, we ought to be indebted. I am, for one, but I'm going to bother you one last time if you might be able to help. Since the facts are important, here we go:
a) Like new (but old) Evinrude '96 55lb Thrust Trolling Motor, bow mount, foot controlled;
b) Four Prong plug, '96 Stratos, 201 FS
c) New Batteries
d) Thight Clean Connections
e) Four red wires coming from the front to the batteries (trolling motor looks like two reds, a white and black)
f) 12/24 Volt Switch at the foot pedal
g) Batteries wired straight with no jumpers
Here's the problem: I have 12 volts showing in the plug socket holes at the bow. I do have two speeds, one for each of the 12/24 settings of the swith, and when switched to 24 volts the power is considerably greater than when at 24. So, I assume the switch is achieving 24 volts somehow. However, the 12 volt setting seems way too weak, and when I use the Trolling Motor in the water, the power is extremely weak at both 12 and 24 volts. A total drag. At the 12 volt setting in the water, it's like a child's toy. And at 24 it's nowhere near how it was originally.
Out of the water, the speeds and power (just playing with it) seem strong only at the 24volt setting. In fact it seems stronger than when it drops down into the water for use.
My questions probably aren't easy ones: Could I still have the wires incorrectly set if I have two speeds at the switch? Does that necessarily rule out a wiring problem? Is there a way to tell which wire is which when I check the wiring? Heck, they're all red at the batteries.
Thanks, Silvertip, and sorry for the bother. You've already written an encyclopedia on this topic.
I'd of course value the opinions of anyone else knowledgeable to the issue and who might care to respond.
KVH
c) New Batteries
KVH
