I just replaced the cam follower on my 15 hp Evinrude. I think I got lucky in that it seems to run fairly well. Good response to throttle and seems to rev up 'real' high... I do not have a small engine tach (any suggestions?) and it is not under load (running with muffs) so I can't say for sure the high end revs are correct yet... I assume that with no load I should not go WOT for long...
Question is: how do I adjust the Cam Follower? I thing the old one was NOT set correctly as the screw was almost all the way in and looking at the new one, my guess is that that would put a lot of stress on the arm and probably break this one too...
Actually I did get it in the water for a while. Seemed a little rough at 3/4 throttle, smooth at WOT and wanted to stall at idle after running around the lake for a while... Started right back up but needed choke and full enrichment on the mixture screw...
Thanks in advance...
Ray L.
Ray L.
