Cam question
77searay197
I have decided to put a vortec 4.3 motor out of a 99 silverado. I?ve heard this cam would work in a boat but I wasn?t sure. I?ve tried to search for a cam that will fit av6 vortec with a balanced shaft and I?m having a hard time finding something that doesn?t have too much lift and that fits the rpm range I?m needing. Anyone know of a nice cam that will work and not have to worry about reversion or having to upgrade my springs?
77searay197
I seen crane cams had this one but I didn?t know I?f the lift would be too much or not. I also seen comp cams has a cam you can have them grind but not sure what to tell them.
Note: Good low end torque, smooth idle, daily usage, light towing, economy, also mild turbo- charged, 2200- 3000 cruise RPM, 8.0 to 9.5 compression ratio advised.
Grind Number: HR-204/286-2S-12Operating Range:1200-5200 RPMDuration Advertised:260? Intake / 276? ExhaustDuration @ .050'' Lift:204? Intake / 214? ExhaustValve Lift w/1.5 Rockers:.429'' Intake / .430'' ExhaustLobe Separation Angle:112?Max Lift Angle:107? ATDC Intake / 117? BTDC ExhaustOpen/Close @.050'' Cam Lift:Intake - (5?) ATDC (opens) / 29? ABDC (closes)
Exhaust - 43? BBDC (opens) / (9?) BTDC (closes)
Ayuh,.... The stock cam will work just Fine,....
The cam ya listed is abit hotter, 'n will probably also work,....
77searay197
Would that crane cam make much difference at all? It?s almost 300 and I wasn?t gonna spend it if it won?t make much difference. I?m not sure what the stock cam specks are and what the stock springs can handle
77searay197
Also I was wandering about the pulleys. Since my motor has v belts and vortecs have serpentine set ups would I be able to mount my crankshaft pulley on the vortecs balancer and would it lineup with the other pulleys?
Ayuh,.... If ya swap All the pulleys, 'n brackets, Yes, it oughta line up,....
I doubt the cam would make difference enough to "Feel" it in the seat of yer pants,....
Ayuh,.... Which ever was on the boat's motor,.....
thumpar
I doubt the cam would make a noticeable difference. Use the $ for fuel to get more lake time in.
