Can a 25 hp 4 stroke be modified
tblack111
Re: Can a 25 hp 4 stroke be modified
Underpowered for my boat.....looking for a simple solution in an unsimple world I guess. Got the tracker at a steal. good for 1 man...add another...not enough horses
Mi duckdown
tblack111. I think you have answered your question.
Altough you have not mentioned size of boat. and, if it is a tiller or console?
tblack111
No one has to tell me im underpowered, I know this. My question is ....Can it be modified to produce more? And how much is enough $$$, and what can be done with enough $$$?
Mi duckdown
Size of boat/tiller or console?
But No. you can not increase HP.
Chinewalker
The simple solution is to sell the 25 and get a larger motor.... Probably a cheaper solution in the long run, too...
Silvertip
With enough money you can certainly get more power. But just like race engines, reliability goes down ddramatically. Cam, compression, carburetion (or EFI) are the three "C's" for performance increase in a four stroke engine. Changing only one generally produces very small increases in power. You really need to modify all three. In the end, you end up with a more powerful engine but have spend a boat load of money and you now have an engine that can't run at slow speeds. The advice you have received is valid. Sell the motor and by bigger. Look at the capacity plate on the boat. For acceptable performance you ALWAYS should install an engine that is no less than 70% of that figure. Some manufactdurers and dealers underpower their boats for one reason only -- price.
Handyman1
you can always try a smaller pitch prop you will go slower and have more power
