can and outboard be kept in Salt Water
tonyscj5
I keep my boat in the Bay all summer and am wondering what I should do about the motors. I see some people pulling their motors up, and some even hooking up a hose and flushing, my johnsons dont have a hydraulis tilt. I normally pull them up by hand, but some days leave them down.<br /><br />What should I do? If I going to be back in the mourning do I need to raise the motors.<br /><br />Tony
WillyBWright
Re: can and outboard be kept in Salt Water
Salt will slowly dissolve the aluminum all the time it is in contact with it. You need to minimize their exposure to it. Flushing with fresh water after each use is a must. The internal surfaces are barely protected to bare entirely. Only flushing gets the salt water out. Tilting them out of the water will also help, but not so much if you just trap the salt water inside because the motors won't drain properly when tilted.<br /><br />Other things that help are electrical in nature. Electricity accelerates the process. You can easily remove that factor by installing battery switches and turning them off when the boat isn't being used. Galvanic corrosion is also electrical in nature, but there is only a limited number of things you can do about that. Different metals in close proximity in a bath of conductive saltwater turns each motor into somewhat of a battery itself. The most reactive metal will be the first to dissolve. Aluminum is very reactive. But Zinc is more reactive. So there are chunks of it placed strategically on the motor to sacrifice themselves instead of the aluminum. They have to be replaced when they dissolve enough, and they have to be free of grease and paint so they can make good contact with the saltwater.<br /><br />If you do nothing, those motors will dissolve to uselessness in a matter of a few years. If you take good care of them, you can easily triple to quadruple their lives.
rodbolt
hello<br /> my 120 stays in year round and has since 1998.<br /> if I tilt it up it fills the carbs with oil so i leave it down. i was out last night and mine has not dissapeared yet. i do reccomend a good aluminum anti-fouling paint.<br /> good luck and keep posting
rickdb1boat
And if you do raise it, a flushing would certainly help, if possible in your situation. I would at least pull the boat out once a year and use Saltaway to flush out the build-up from the season. If you are just leaving it overnight or continuing use, I would not be concerned at this point..
Jack Shellac
It's best if you can flush your motor with fresh water, but I live on salt water and have neighbors that have never flushed their motors out. Most of them are older OMC's that have had the long reputation of holding up in salt water. They just keep on running. I think I'd tilt mine up out of the water when I wasn't using it. Like Rick says. always flush it with Saltaway once you have it out of the water.
JB
General Outboard (non-repair topics)
