Can anybody help with a window question?
Jeremy90bay
I have a broken window on my 1990 Capri. All the glass is gone except for the out side of the frame. does anyone know what holds that glass in. I just need it out to put new plexy in.
gcboat
Re: Can anybody help with a window question?
Search around the outside of your window frame - you're looking for some small phillips screws. I believe the frames are installed using them to hold it all together. You might need to pull the whole unit from the boat to have access to the bottom ones - not 100% certain but a start. :confused:
