TampaBoater
- Joined
- Feb 23, 2012
- 207
I have a 1985 mercury black max 175, and I notice that right above the rectifier, there's alittle black piece bolted to the block. It's round, no larger than a baby carrott, and has a black wire grounded to the block, and a balck and green wire cut off right at the base, that hooks to this little piece via a nut.
Can Anyone identify what this little piece is? I don't suppose it should be cut offlike it is.
Here's a pic.
Update: My motor still bogs down when at higher rpms, and not due to overheating. The water coming out the back when it starts to slow down is not super hot, not even steam, it's fairly warm but not to the point where I have to pull hand away. It's fineat idle, and low revs, but 2 minutes into 3/4 throttle, the motor starts to sound like it's slowing down w/o even touching the throttle. I am becoming aggravated. I pprobably will take to tech to get compression check. Any thoughts?
Here's a pic.
