Can anyone identify this boat / hull ?
Slaviolette
Hi,
I should be getting this boat hull for free and make it a winter restoration project. The current doesn't know much except that its likely 17 or 18ft long.. I am trying to figure out the manufacturer / model of the boat to start to do some research before I am able to drive over there to pick it up, anyone seen it before ?
jbcurt00
Free boats are often the most expensive to rehab.
1st guess is its a foam filled hull lik a Whaler, and may have mush more work ahead then you expect.
More pix might help w an ID.
Even free, it better come w papereork, else it can be quite difficult to get legal paperwork.
Paperwork should have a HIN which will give you some info if the HIN isnt visible on the top right corner of the transom
Good luck w your project.
