Can anyone recomend a mooring system? Please help!
fastman14609
Can anyone tell me how to setup a mooring system for my boat? I can not put a dock in this season in front of my house, because the breakwall is rotted out and i can not replace till next year! Therefore i have to setup some type of mooring system. want to have the easy system possible,I am kind of new to this so forgive my ignorance.<br />boat specs to be moored<br />22' caribe w/big block, closed bow<br />thanks for your help!
pine island fred
Re: Can anyone recomend a mooring system? Please help!
Tough to answer without seeing it. Consider jetting a few 4X6s into the bottom. 8 or 10 ft. lenghts are pretty easy to handle and once set in the mud are pretty secure. Jet tubes are easy to make with a few lenghts of pvc tubing. Works for me but I am on a canal not open water. fred
fastman14609
Thats not the way i want to do it, I was thinking about using an anchor and buoy! no docking system.
tommays
You need a big mushroom at least 250 # if you don't want to chase the boat during a storm X feet of chain and a float big enough to hold the chain all the shackles should be safety wired<br /><br />i havent seen one sold as a complet system you usally have to pick out the parts to suit you needs to many diferent boats and things<br /><br /><br />When you drop it in the water are sure you're in a good and legal place cause it's really hard to pull up again<br /><br /><br />you have to be sure the boats not going to hit anything in the mooring circle <br /><br />down here on long island you cant just drop one were every you want there may be some rules up there to<br /><br /><br />tommays
fastman14609
Not sure on the legal end of it,But it will be in front of my house, so i do not think it will be a problem.Is there anywhere on the net that i can look up a drawing of how to do this setup? Only problem i see is that i will have to take a raft from my breakwall to the boat.But that is not a big deal.I will just be happy to be out on the water.
BillP
If its a sand bottom buy 3-4 large danforths and spread them out equally with proper scope. Tie all together with chain and lead to the center. Hook a bridle up from there to your boat. Use large nylon.<br /><br />If it's only for a season use 2 anchors, each with a short (10')length of chain and nylon line @ 10:1 scope. I anchored sailboats several yrs off our shoreline with two. Just make sure the boat stays in the center so the lines won't trip each other.
mattttt25
the actual mooring system is explained above pretty well. you need something heavy or that will secure well. got a junkyard near by? old engine block would work well. secure chain to it, then a buoy.<br /><br />here's something i almost did one time. off the top of the buoy, mount a pulley and run heavy cord or steel cable to the beach. see what i'm getting at? with a place to secure the bow to along the cable, you can operate the pulley and drag your boat to the beach. when you're done, you pulley it out to deeper water. i don't know if it would work, but it made sense to me.
fastman14609
Good idea matt! Thanks for all the help guys!
fastman14609
Going to give this mooring thing a shot! hopefully my boat will not drift out to sea!
Israel Hands
I've built several using by pouring concrete into forms: the bigger the boat, the bigger the form. Use a blow torch to heat a 2 foot lenght of rebar in the middle and bend into a "V" and insert into the concrete and attach chain or rode. I onced used a truck inner tube as my form. Floated it out into the bay and let the air out.<br /><br />Israel hands
roscoe
The problem with concrete is that you really need more weight when using concrete, than steel. Reason being that the concrete is not as dense and is actually more bouyant once it is in the water, and it doesn't sink into the sand or mud as well..<br /><br />I worked for a guy that put moorings in, on Lake Michigan. He had a 36' (?) barge with a small crane. We would load it up and head out across the mooring field every spring, dropping them off the barge as we went. We picked them up in the fall, and he serviced the chains, shackles, lines, etc, over the winter months<br /><br />The best weights were the old railroad wheels. They never moved. Small wheels for small boats, big wheels for big boats.<br />Some customers would supply their own homemade weights which was ok, but some did not hold well. Now this was Lake Michigan and a very congested mooring field. We couldn't use as much scope as we wanted because of being so crowded, so we had to have weights that would not move.<br /><br />Some guys would not pay for the service and put them in themselves. Seen a guy in a 14' rowboat with some planks across the gunnels and a huge chunk of steel on top of the planks. He rowed out to a location and tried to push it off, but couldn't. So he pulled the plug on the boat and let it fill half way up with water. Now he was able to tip the boat and let the weight fall in the water. He was making very slow headway back to shore with the water filled boat, when someone towed him in.<br /><br />Where there's a will, there's a way. :)
MrBill
Fastman...you could provide more information and get some better answers, like wate depth, lake bottom conditions, etc, but here's what myself and most others do around the lake I'm on. Metal, like railroad engine wheel is ideal but hard to come by, most of us have the local concrete plant make up round (3 ft diameter, 6" thick) mooring "caps" outfitted with a "U" embedded. Getting it to the location is not easy. Connect galvanized chain to the "cap" and to a mooring ball with a stainless swivel. Chain length should be approximately 1.5 to 2 times depth of water. Attach nylon rope from mooring ball to boat using pre-made one with 3/4" nylon and appropriate stainless hardware, including swivel and clasp. With mooring ball will be good instruction for set-up. Be sure set-screws and similar threaded bolts with holes are "cottered" to prevent loosening that inevidibly occurs with the constant motion of moving water. Hopes this helps, a marine dealer can also help...don't under-estimate what constant grinding, tugging and motion can do to chains, ropes and parts, use high quality, heavy duty stuff.
fastman14609
Mr bill thanks for the info! I have not picked the boat up yet therfore i do not know the weight.I will be in about 15 to 20 ft deep water,I will shoot you an email when i get the weight of the boat.Thanks for all your help guys!
cjones4@hvc.rr.com
We used to use the pulley system on smaller boats, maybe you could rig one up as Matt suggested. The way we did it was to sink a long pole in the mud at low tide and attach a clothes line pulley to it. Both ends of rope around the pulley were tied to a large metal ring and the boat secured to the ring. the doubled line was secured onshore around a pole. Untie and pull the boat in to shore like bringing in the laundry.
malagaoth
i use a train (loco) wheel it weights about 500lbs and holds my 20 ft in a tidal flow of upto 4knts. once its in it sucks down on the mud bottom.
SELLADAM
I've also heard of people going to the junk yard and picking up an old engine block to use as a mooring weight.
