Hi guys, I'm looking for a little advise here. I have a 16' duranautic boat that is an aluminum hull. It appears that there were some panels of the boat made out of PT plywood. The panels have been wrapped in carpet and there is no actual wood in contact with the aluminum of the boat. I was curious if this was ok and would prevent corrosion or if these panels need to be removed and constructed from standard plywood. The carpet on these panels is wrapped over the wood by about 8-10" in most areas on the rear of the panels. I was not sure and couldn't find any answers on if the metal needs to be in direct contact with the wood to create corrosion or if the treatment would basically transfer through something like carpet and still create problems. Any advise on this would be great. Thank you.
