Can Cedar handle it
roy c
can cedar be glassed over? I was researching this so when I start my R&R of transum
and stringers bulkheads wondering if it would work for motor mount surface 4x4 type
No, not strong enough to lag into
AShipShow
I think depending on the type of cedar there's also issues with the oils inthe wood causing issues with bonding to the resin
sheboyganjohn
You can glass over cedar. Most cedar strip boats have a 6oz cloth on them with epoxy resin. Not sure how poly would behave. I agree with Scott that strength could be an issue. I see no benefit in using cedar over pine if you are following proper building and sealing techniques.
Woodonglass
I know you asked this because Cedar is so rot resistant. Here's what you need to understand. Wood does not rot unless it is exposed to outside contaminants. IF you do a good and proper encapsulation of the wood and nothing happens to Break that protective barrier it will NOT rot. Doesn't matter how "BAD" the choice. The other consideration when selecting wood should also be it's structural Strength. Cedar does not have a very high rating. Most softwoods don't. Hardwoods do. The reason most people use plywood instead of dimensional lumber is...The RESIN that holds the wood laminations together. This gives the plywood it's strength Bottom Line...use ext. Grade plywood for all your wood pieces (Unless they're for cosmetic purposes) and concentrate on doing a Great job of fiberglassing.
