Can Gluvit Displace Oil?
Grandad
I'm currently repairing the aluminum hull on my 1972 21' Starcraft Holiday. Fatigue cracks have developed at the portside ends of 4 amidship ribs. I'm confident in my plan to patch and reinforce the hull and will start a thread at some time to report my progress. For now, I have a question for anyone who has had any long term experience with sealers such as Gluvit.
After cleaning 39 years of bilge oil off the hull with waterless hand cleaner, I'm well aware that although the open areas are clean and shiny as new, there must still be a film of oil crud that has seeped into every crevice including those around a few as yet undetected leaking rivet heads under a rib somewhere. I can't believe that Gluvit can be expected to seep into these oily crevices, displace the oil residue, bond to the aluminum and permanently seal out water.
Has anyone had long term success (not current projects) where Gluvit alone can be credited without having first replaced or bucked leaking rivets?
Thanks, Grandad
jspansel
Re: Can Gluvit Displace Oil?
I used Gluvit on my riveted 13' last year and it has been absolutely great and leak free since! Love the stuff. Must be painted over though as no UV inhibiters (if its exposed to sunlight). I did not re-buck any rivets or anything. Just slapped it on, let it cure, and painted back over it.
Woodonglass
Grandad, slop around a LOT of acetone in there and let it soak as best you can an then take it to the car wash and Pressure wash it out as best you can,then put the Gluvit to her. She'll be sealed up tight!!!!
Grandad
Thanks guys. I have Gluvit on order. Not easy to find in Canada. I appreciate your comments. Gonna give it a shot. Bought more acetone today. - Grandad
