Can I bore out a 60hp Evinrude?
Does anyone have any idea if I can bore out my 60hp evinrude to give it a little more get up and go? Is it very expensive and is it alot of trouble? Thank you in advance...
jimmbo
Re: Can I bore out a 60hp Evinrude?
Yes to all 3 questions, however the increase if any will only be 2 maybe 3 horsepower. Since the 60 has been made as 2, 3, and 4 cylinder versions, it can get expensive.
walleyehed
If you want to do this for a performance increase, don't waste your money.....there will be no noticable difference.<br />Maximizing your set-up will add more performance potential than anything with the exception of adding 50 more HP.
walleyehed
BFW2much, how much "extra" performance are you looking for and in what areas???
Walleyehed,<br />I'm just looking to speed the boat up a little. Actually, as much as possible without having to go out and buy a different motor. Right now it runs around 35-36 mph. Maybe get it in the low 40s. I appreciate your help. Thank you...
Triton II
Increasing speed is difficult to do with power alone. This is because the amount of drag any given hull/motor combination has goes up in proportion to the velocity squared. I.e. If you double the speed, the drag goes up by a factor of four. This is not only applicable to hull drag but also to air drag. So, as walleyehed states, minimise your hull drag by optimising the performance with the motor you currently have (Raising the motor, repropping if necessary to achieve the top end of your WOT range, trimming properly, putting your passengers in the optimum place in the boat, keep the boat dry etc, etc.) You can also minimise air drag: if fitted make sure your bimini is not acting like a parachute or air brake, get rid of excess rocket launchers, etc. To achieve an increase of 7 or 8 mph will take a fair bit of power because the drag increases so much... you'd need at least 30hp more IMO. 2 or 3 hp will make hardly any difference, but optimising your set up will.
Triton II,<br />Thanks for the advice. So do you all think my best bet is to go with a different prop and to maximize every other option besides the engine to boost the speed a little? Thanks again. You guys have been great...
Triton II
Yep, you got it in one. Enjoy your experimenting...
walleyehed
BFW2much, what prop (manufacture and size) do you have now?<br />Is your engine setting directly on the transom, or is it up a hole or so (Top bolts), and what boat are you running this on?
Dhadley
Lets start at the begining. As Jimmbo pointed out there were several versions of the 60 hp. Tell us which one you have and about the set up. What rpms, boat etc as the guys have asked.<br /><br />The first thing is to establish what you have and where youre at now. Then you can figure out how to get where you want to be. You need to max out the set up now with the prop you have before you change props. <br /><br />Establish a baseline. Make one change at a time.
The engine is a 1989 model 60hp Evinrude, oil injected, three cylinder. It is on a 1989 16' Nitro bass boat. It has the original steel 3 blade prop on it. The engine sits directly on the transom (tilt and trim by the way). Changing the prop would probably be my first step huh? Since it's just the old original one? Thanks again for your help everyone. It's much appreciated...
walleyehed
There's a chance that some cupping is gone due to wear, but I think I would start by moving the engine up a hole and test...keep going up until it ventilates, then move down one.<br />See what improvements you get at that point, then we'll look into a prop. What RPM are you turning at max???
I feel dumb, but I'm not very mechanically inclined. I'm not sure what RPMs I'm turning at. How would I be able to figure that out? I'm sorry I don't know this. I'm new to boats and have never known to much about mechanics. Thanks for your patience and understanding...
Solittle
Knowing the RPMs at wide open throttle is the first step in maxing out your performance. Go to the red search at the top of the page and enter tach or tachometer and read away. Look for info on a tach that I think is called Tiny Tach or something close to it. It can be purchased and added to you rig to give you the RPM readings. Then post back and our "experts" will advise what to do next.
walleyehed
BFW2much, don't even think about feeling dumb...It's better to ask than to assume.<br />You're at the right place and I'm sure you can get the help you need here.<br />SoLittle says get a tach, that would be a recommendation I would give as well, and this is a good time to understand the tach is most likely the most important instrument you can have.
Okay, <br />The boat has a tach, I just wasn't sure what you all were looking for as in max RPM. So I need to get the read out of the RPMs when the boat is at full speed with the throttle wide open? I can do that. I'll be taking the boat out tomorrow, so I'll post it in the evening tomorrow. Thanks again fellas...
walleyehed
That's the ticket....see what she'll do WFO and post back!
Alright guys,<br />Took the boat out this afternoon and she ran like a top. The max Rpm was right at 5500. I don't really know what that means, but I sure hope I can get her to run just a little faster. The boat really gets to top speed quick, it's just that top speed isn't that great. I was looking at the prop, and it's not in the best condition. One of the blades actually has a nock in it. Well, if you have any ideas, shoot... Thank you again, as always.<br />Cody
walleyehed
BFW2much, first thing I would do is lift the engine up a hole-it's very simple to do- and test.<br />Always start out trimmed clear in and see how far out you can trim while at WOT before it ventilates...<br />Let's go up as far as we can until we see a ventilation issue (prop-slip, high revs).<br />We need to see about 5700-5800 RPM, or higher.<br />Lifting the engine will decrease lower unit drag, and increase RPM. If we can get it up just to the point it wants to vent., we can look at some good props that will harness the available power you have.<br />A fixed jackplate may be an option as well, with 3-1/2-5" setback. 4-5 MPH isn't out of the question here.
