Can I change gimbal bearign with just outdrive removed or need to remove bell housing
pcweber
Is there a reason to pull bell housing to replace gimbal bearing or can it all be done with it in place and just the outdrive pulled?
ricovw
Re: Can I change gimbal bearign with just outdrive removed or need to remove bell hou
In place with the drive removed? You will need an internal slide hammer bearing puller. As well as an installation too. I made mine, but I'm a machinist.
tpenfield
No reason to pull anything other than the outdrive. Bearing pull and installation tool is highly advisable. Grab yourself a manual for the outdrive off of the internet.
ricovw
Sorry, that wasn't supposed to be a question (?) mark. Supposed to be a period.
greg82255
You can go rent a slide hammer from autozone and pull it out right through the bellows. No need to remove anything besides the drive.
