According to the parts schematic, the carbs are exactly the same. How do you raise the exhaust timing? My daughter just started college, I don't see a new motor in my future.
The 90 hp carbs are WME-5's and the 75 are WME-6, the differences being the cast in emulsion tubes and idle port pockets otherwise they look the same. To raise the port timing you will need to remove and disassemble powerhead and take to a machine shop and have ports raised on a Bridgeport mill, you can do it by hand it you make a pattern from a split sleeve that been hardened so you dont take to much..According to the parts schematic, the carbs are exactly the same.
