Re: can I do this ???
Ayuh,.....
On my present barge with the Alpha 1 drive, I fought a slight occasional Overheat issue for Years...
Til I figured out you Need the check-balls in the T-stat housing with the early Alphas....
I guess the check-balls went away with the change to the Gen.II Alphas....
The barge that I'm puttering with now,....
Was going to get Either the Gen.I, or the Gen.II, as I have both transom assemblies laying around...
But,...
I pulled a Cool Deal last summer,+ picked up a Complete Bravo I early edition(outdrive,+ transom assembly),+ a complete Alpha 1 gen.I outdrive for a mere $1300.....
Now I have another Spare Alpha 1 drive for the present barge,....
And,...
The Old Town Atlantis project will be getting the Bravo I hung on it,+ the bored & stroked 327 in it....
Bottom line is,... I now have alittle more breathing room to play with the 383 build....
And it'll be fed by a block mounted raw waterpump,+ a thru-hull fitting...
(and probably freshwater cooled,.. only because I have a system laying around,.. probably need Another pressure gauge then, huh,??
I wouldn't have Thought that either the earlier Alphas, or the Gen.IIs would support running
Just a Cross-over tube.....
I know the Cross-over tubes are popular with the serious Jetboaters,...
But,..
With a V8 spinning a Real Jetpump,....
It's a question of Limiting the water, not how Much there is....
