balliztic bucket
- Joined
- Jul 2, 2008
- 5
The fiberglass flooring in my boat is cracking and warping up off the plywood, the wood looks wet right now because I just sprayed out all the bees nests but its not rotted. However it is slightly spongy under a stomp. So my question is can I get away with just scraping the loose stuff off, sweeping/vaccuuming, then just fiberglassing over the top and then drilling out the floor vent holes(is that what those are there for? theres 2 on left and 1 on right) Or option2, after cleaning, lay resin, 3/8 ply,then fiberglass matting over the top of that then, drilling my floor vent holes and fibering them? Can I cover or plug those holes? Or could I fill them with spray foam to add boyencey? Or must I keep them open? My trandsom is all free of dry rot so is the rest but I want to add strength without adding weight. The boat will never see over 30mphs and it will be a flowerbed by next summer but I want to get on the water this summer. will adding wood be to heavy or will it help it float? Diddo for the the foam? my e-mail is tuffytime@msn.com
