Can i install a different Year fuel pump.
Rich976usaf
OK i have a 85 115 v4 vro. i know that one of the one way valve on the compression part of the pump is busted. I have disabled the vro and use premix. Can I install a different year pump that is not vro and not the same year pump. I think i want to put a 82 pump on. This is before the original manufactures conversion to vro style. These pumps are more than $100 less. I believe this pump still works on the engine compression. Does anyone know. Have anyone ever tried this.
gejandsons
Re: Can i install a different Year fuel pump.
That looks like the one installed on my '89 Evinrude 110 to replace the original VRO pump. I just had Hernia surgery yesterday, as soon as I get get outside I'll take some Pics of mine & Email them to you. You'll be able to see where it is mounted & where the vacuum line is attached.
gejandsons
Pics, hope they help.
tashasdaddy
good luck on your recovery.
rickdb1boat
Pump # 438559 will do it..
Rich976usaf
Thats the pump i installed inplace of the VRO pump. It works well, but it did not solve all the problems. It no longer stalls. Im gonna now check the timimg. This is a project rebuilt. I could see how the timing is off. Hope it goes well today.
Good luck on your recovery.
voodoo
I installed a 3 port Mikuni snowmobile pump on my triple. It will idle all day and there is no fear of a stall powering it up.
It was either the low compression in number 3 or the pump was weak.
