Can I Just bolt on my evinrude 140hp (early 80's) ro do I need to install...
johnny_boy
Stainless steel through transom dowels? I have just laminated a new transom and there was dowels in the old one, but are they really necesary? Can I just fill with epoxy mixed with microfibres, redrill and seal with sikaflex and bolt up with big S/S washers?
jonesg
Re: Can I Just bolt on my evinrude 140hp (early 80's) ro do I need to install...
" have just laminated a new transom "
hard to understand what that means, did you remove the old transom and install a new one?
if so all you need do is drill holes and seal the bolts with 5200,
run it thru the hole with your finger and smear it on the bolt shaft.
Installing dowels is usually done to seal up old bolt holes when installing a different engine with different spacing for the bolts.
I found my transom got wet from poor installation of senders at the bottom near the keel, depth finder mounting screws with no sealant.:eek:
johnny_boy
Sorry about the confusion, yes I have indeed replaced the transom, so I have new timber to drill through. The reason for my question was because the transom I removed didn't have dowels to fill old holes, but stainless steel tubes that obviously previously protected the transom from the outboard mounting bolts. I have read about instances of the motor bolts chewing into the transom, sometimes after towing, which causes the holes to elongate and the transom to deteriorate. I am not going to be doing much towing, but wanted to get some feedback to determine whether it was still important to do. Your way would certainly be quicker and easier. Can anyone tell me what size bolts I need to order for this motor? Many Thanks,...
jonesg
Measure the holes in your brackets and buy stainless bolts, washers and nylon insert locnuts. I think they're approx 1/2 inch dia or slightly bigger,
measure transom thicknessplus bracket for length. I recall approx 5 inch.
Depends on your transom though, obviously. Just slip a dowel thru and measure that.
I use 2 large fender washers and 1 spring washer on each bolt, put the spring washer under the nut. Stainless bolts are pricey, I think it cost me $40 for the 4 bolts w/ nuts and washers.
I bet they used those steel tube inserts to prevent the transom from compressing due to rot.
A properly mounted transom doesn't need any bolt reinforcement no matter what you tow.
