I thought it didn't go at all, spun prop??? Did you solve it? Yes you can , it will cost you some coin to convert it to a 15hp.
Build yourself a dual carb, dual reed plate manifold (Homelite pyramid reed plates). Install a pair of Tillotson chainsaw carbs with 3/4" venturis and 50% larger area jets.
Convert the ignition to a maverick magneto so that you can advance timing about 40*. Set up the link 'n' synch so that you can turn her about 10Krpm and put a 4" prop on her.
Then mix up some fuel: 1 pint of Fox Hi Nitro glo plug fuel to 1 gallon of methanol.
Will go like stink and scream like a glo plug engine.
Rebuild after every 2 hours of operation, if it should last that long.
I'm just a little bored and want to go faster but can't afford a new, faster one. Is it possible or is it really worth it?
Thanks, Chris
Strap a ACME Rocket on top of the motor and light the fusePut on a helmet and hold on to your britches. For guidance I'm sure you can pull up a Roadrunner/Wile E Coyote cartoon on youtube
LOL Sorry couldn't help myself
cajuncook1
Check out what this guy did. Smaller boat though. But fast.
http://www.youtube.com/watch?v=TsL8FCrLHg0
you can lose weight.
