Hi guys.
When I tow my boat in daylight, the signals on the trailer are barely visible. When I turn my running lights on, all the lights are clearly visible, but the signals are still low.
Using a voltmeter (set at 10V scale), I determined that the connection at my vehicle's plug is dishing out 10+ (off the scale) volts to my nice, normal, bright, easily visible trailer running lights. However, the voltages for both left and right signals top out at about 5.5 volts. I tested the voltage at my trailer lights and an still getting about 5.25ish volts, so not much loss. Inside the vehicle, I tested upstream from where my wiring harness is coupled, and same, my vehicle only dishes out a max of 5.5 volts to both left and right signal lights.
The vehicle is a 1999 Jeep Cherokee Sport. Is it normal for signal voltages to be half or less than the voltage sent to running lights? The vehicle's signal brightness seems normal at this voltage. But the trailer lights barely show the signal.
What should I check? Is there a way to increase the voltage that the vehicle sends out to signal lights?
Thanks so much.
Libbs
Thanks so much.
Libbs
