Re: Can I manufacture a kill switch for a 9.9?
Yea, you could rig a switch....have you metered the 2 wire leads with an Ohm meter to see if the wires are shorted when you press the button? Perhaps one of the wires is 'open' (broken). Meter each wire from switch to connector/ring end. Replacement switches are approx. 36.00. Have you inspected both sides of the connector for corrosion? One wire should be grounded to the lower pan or power head, the other to a connector. going to the power pack.
The switch is basically a Momentary Type -Normally Open Single Pole switch. A Single Pole Normally Open type switch will work too. Cut off old switch, connect the 2 wires to new switch..done..
You'd have to cut a mounting hole in the lower motor cover. You have options, replacement with OEM looks nicer too. Personally, I'd try grounding the lead going to the connector (when running) to confirm motor kill before I drilled any holes. This will rule out a defective power pack kill circuit, but that's just me.
BTW, that kill wire will have +/- 250 volts on it when running.....
