can I pour premixed gas into my jeep?
patrick4266
I have some old, 2 months but I did use sta bil, gas and I want to use fresh gas as I am trying to get my motor running right and I want to eliminate all possibilites. Anyway can I pour it in my jeep?
tinker2584
Re: can I pour premixed gas into my jeep?
Yes, just dilute it with some new gas into your Jeep tank.I've done it many times.
jonesg
Me too, it liked it so I did it again.:)
AEROCOOK
I have disposed of small amounts of premix gas (not 5 gallons at a time) in my van without incident but I wouldent put it in if it were really old and sour, I also made sure that the fuel tank in the vehicle was at or above 3/4 full. At 2 months old, I doubt if your fuel is bad, do you have running issues with your motor?
jimdd810
My Dodge burrped and said may I please have another! yep go for it
tashasdaddy
if you have a friend in the landscape maintenance business, he would love to get it.
kenmyfam
Been running my lawnmower on it for years.
1946Zephyr
I say add some oil to it (16:1) then put it in your Jeep. Good way to get rid of the mosquitos out of your yard:D:D:D
petryshyn
a little now and then won't hurt, but a steady diet of premix could cake up the O2 sensor and catalytic converter.....
F_R
So, you suspect there is something wrong with the gas, causing your outboard to not run right, huh?
Lemme ask you--IF there really is something wrong with the gas, do you really want it in your Jeep? Do you want Jeep problems added to your outboard problem?
Bad gas has only one proper destination---the recyclers. If it isn't bad, then why are you trying to get rid of it?
Al-53
2 month old gas is not long....I have 12 gallons in the boat over the winter..I use marine stabil and sea foam.. for storage..come spring she fires right up....runs like a swiss clock...
that gas should fire off with no problem...I would just run it...as long as it was sealed from the elements and no water got to it...
Al
