Re: Can I put a trim guage on?
On your OMC units the trim sender is located on the stbd. side of the leg. Little round, plastic gizmo. Turn your wheel hard over to port and you should be able to see it. Now, look on the inside of your boat at the drive unit itself. Right below the steering link there will be a wire coming out of there - that is your wire for the actual sender. Now all you need to do is find the appropriate adaptor and install your dash unit and you should be good to go. HOWEVER - this is on my 1989 OMC leg, yours might be different but I don't think it will be. I guess one size fits all. Calibrating it is another situation. Directions should come with the gauge you buy.
Bigprairie1 - I'm not at all familiar with those Force outboards - sorry.
