Re: Can I rebuild a '73 888 ford 302 fuel pump?
http://www.uscgboating.org/regulations/boatbuilder_s_handbook/fuel_standards_partl.aspx
Here are some of the regs..
Fuel filters, strainers, and their connections must withstand a 2-1/2 minute fire test conducted as described in 183.590. "... Took me 5 seconds to google "USCG regulations on fuel systems" Never seen a plastic piece withstand 2 1/2 minutes fire test, myself. The rubber fuel line hoses must be
Approved type A1 fire retardant hose
I suppose that if one wants to split hairs and say this is for builders and not individuals that don't care what builders need to do, then I guess it's up to one's interpretation. BUT, fuel filters with the plastic bowls are specifically labled that they are not approved for use within the engine compartment of an inboard / IO boat. All I know is that when the CG Marine Inspector sees a plastic fuel component within an engine compartment of a gasoline fueled water craft, the operator will be cited. Have seen it happen.......
I, for one, will follow the requirments for builders and caution labels placed upon the components / thier packaging,
only using approved components, just play it safe. And I'll bet a pay check that if a fire / explosion happens and plastic components are found to be installed where they aren't supposed to be, there
may be a problem w/ insurance company and one may have a hard time trying to defend against a law suite from owners of other boats that may have been damaged as a result of said fire / explosion, if one happens. Easy call for me.....
If the plastic components are not in the engine compartment, then the whole point of the replies is moot..
