1985 150 HP Black Max XR2<br /><br />Intermittent spark on No 4 cylinder.<br />Some days it's there some days it's not. Today it's not. Swapped coils between #2 and #4 and still no spark on #4. Checked voltage with DVA and jumped around but way low at about 25 V. Others at 185V +.<br />I suspect, based on what I've learned mostly from you guys, a bad SCR in one switchbox.<br />The outputs from the switchboxes are Grn-Red,Grn-Wht and Grn. Inner switchbox feeds 1,3,5 cyls., outer box feeds 2,4,6.<br />Can I swap them, that is one bank to the other, and if I can will the non sparking cylinder move to #3 as confirmation.<br />Seems like I read a post that you could, but I can't find it now. <br />Thanks, Dave.
