dheitman62
- Joined
- Dec 14, 2010
- 19
I have a 1965 Johnson 9.5 hp model MQ11c. This motor uses a 3 Blade aluminum prop (OMC #377635). I think the hub in this prop is starting to slip. I have a 2 Blade prop from a 1969 6 hp engine that has never been used (OMC#380958) It installs the exact same way as the 3 Blade prop using a prop nut and cotter pin. I would like to know if I can use this 2 Blade prop on my motor. What difference would only having 2 Blades make and, if I did use the 2 Blade prop, could it damage my engine?
Thanks in advance for any advice on this matter.
