Can I use Carberator cleaner on my 67 Johnson
Patty Pooh
I am not getting fuel to my carbs. Can I use the cleaner to remove any deposits?
Chinewalker
Re: Can I use Carberator cleaner on my 67 Johnson
The only way to properly clean carbs is to remove them and disassemble them. ONLY then can carb cleaner be used. Simply spraying carb cleaner on or in the carbs will result in a clean exterior and throats. The real gunk is in the carb bodies...<br />- Scott
JB
Hi, Patty Pooh.<br /><br />Ditto Scott.<br /><br />However, if you are accurate that you aren't getting fuel TO your carbs you need to look at your fuel supply system.<br /><br />Can you give us some more info? Model of your engine, actual symptoms, etc.?<br /><br />Good luck. :)
ob
