can I use scotchbrite instead of sandpaper for all my prep and painting on an al boat
jtrom
I think it will get between the rivets better. What color do I use for the final sand before I paint?
Yacht Dr.
Re: can I use scotchbrite instead of sandpaper for all my prep and painting on an al
Well now that all depends on your Primer coat .. and what the primer suggests.
I would say NO at this point.
Yes you could/should use a red scotch bright around your fittings Before doing an all around Prep for Pre-primer/primer coats..
What stage are you at ? .. Pics ? .. what paint system ? .. .. Soo many Variables ..
YD.
jtrom
Right now I'm stripping all paint with zip strip and brown scotch brite pads...I'm wondering what color scotchbrite to use BEFORE the alumiprep and alodine steps......
Stratohammer
We use red on airplanes. The point is to make sure all the paint bits and any spots of corrosion are gone.
Mike
