Can I use this broken part? (photo)
craig4wd
I'm putting my Force90 back together and the crank case was freezing up piston movement. So I took it off again and found that this expansion oil seal had busted. It's a nightmare for met to get parts so can anyone tell me if I could get away with putting the ring and the busted bit back in?<br /><br />The ring is captive in a groove so I can't see why it wouldn't work.<br /><br /> Picture of stuffed seal... :confused:
coupedeville
Re: Can I use this broken part? (photo)
You be in da wrong place, mon. Try the outboard forum; Dis be the inboard forum. ;)
craig4wd
Ok, I wasn't sure if it should be in or at. The engine is in a jetboat mounted inside, i.e. it's not an outboard, but being a 2 stroke seems more like it'd be suited to an outboard forum. I'll give it a whirl over there.
