Can I use this prop?
tpenfield
The 'hub' that goes with the prop will decide the fit for the alpha . . . not sure you ordered the hub as well or if you already have one. Did you mean to order a 15" pitch prop? If so, then you may be OK if the boat is very light. On a typical or heavy boat, the prop will not do well for you.
If you did not mean to order a 15" pitch, nor the 15" diameter, then game over.
jimmbo
How does the hub size compare to the old prop/gearcase dia?
If the prop is unused, contact the vendor and see if they will exchange it
timm4433
No Title
Here is a photo of the prop in question. My main concern is the diameter difference between the prop hub and out drive housing. Does this matter?
timm4433
Sorry, for some reason my description wasn't added to the attached photo. I have edited it now.
