nextboat1
- Joined
- Mar 17, 2013
- 82
I recently had some idle issues on my mercruiser 5.7. Thanks to the iboats community that issue has been resolved, but has lead me to my next problem. After fixing the idle issue (rebuilt Carb), I ran the boat on muffs. I checked the temp gauge after running for just a couple minutes and it read right around 100. I then went back to the engine to check for any leaks ect. since this was my first true startup of the year. After about five minutes when it had came down from high idle I went and checked the temp again only to see it was pegged at 240. I quickly shut it down and then went back to check the engine. I felt the risers and all of the hoses and nothing felt hot. I even went as far as putting my hand against the side of the block and still felt no excessive heat. I found that the intake hose from the bellhousing to the transom plate is kinked and in need of replacement. I had water flow just very minimal. My question is, is it possibly that my temp. sending unit had a false reading due to air in the system? I can't believe that I would be able to keep my hand on the risers/block with a temp like that. Any help would be greatly appreciated. Thanks.
I forgot to mention.that the boat is raw water cooled.
