Hi - I need to replace the deck in our 1978 Alumacraft Lunker. Here's the skeleton, with stringers that are 16" apart. I've been working on a plan to replace the old deck, which was installed wrong and rotted out very quickly. I've done some research on Coosa board, plywoods, fiberglassing and epoxy. Here's what I'm thinking. Can someone check my assumptions?
The boat is in service, uncovered, seasonally from May - September.
Thank in advance!
- 1/2" marine plywood (reinforced to 1" where I will install ski pylon... seems like it would be strong enough with 16" stringers)
- Epoxy coating on the plywood, both sides. Any suggestion on # of coats?
- Vinyl flooring
Thank in advance!
