Re: Can someone help me with these prop #'s Please
I think you are misunderstanding what testing involves. I'm not suggesting you buy another prop and test it. The object is quite the opposite. You want to test what you have now -- as in obtain WOT RPM and speed numbers with what you consider an average load. From that baseline it can be determined (with reasonable accuracy) what you "actually need in a prop". With that process you get close. Just buying another prop will guarantee that you pop for the wrong one which we are trying to avoid. Buying a prop based on what someone else has is risky because unless they have the same exact boat, same exact engine, in exactly the same setup, and the engine is in exactly the same condition, prop requirements will be different. And by the way, just because someone tells you they run a 13P prop (or any other for that matter) does not mean it will work best for you because every prop manufacturer has different design critera for their props. Therefore, a 13P aluminum prop from Michigan may not and generally will not perform exactly the same as a 13P aluminum prop from Hustler for example. The only similarity is they are both 13P and probably painted black. Prop selection is partially a crap shoot -- but you can reduce the risk with proper testing.
