Can,t find the block drains on my new boat- please help
CurrentObsession
Trying to winterize my 1999 Powerquest that is new to me this year.
​7.4L 454 MagMPI Gen vi
​Bravo1
raw water cooled (entire system)
Engine # 0l035657
​For the life of me I can find the block drain plugs. On Port side I unscrewed what I though for sure was the drain located right under the exhaust manifold blue drain plug, only to be surprised by oil coming out of it.
​Starboard side I pulled what I now believe to be a knock sensor (that isn't connected to anything and appears to screw into a dead hole?)
​I diagram or pic would be very very much appreciated.
Bt Doctur
about in the middle of the block, just above the oil pan flange are 2 drain plugs. Where each hose connects to the bottom of the exaust manifold is a drain plug, or remove the hose to drain
Bt Doctur
CurrentObsession
So, come to find out I had the correct spot after all, what I thought was oil turned out to be plugged up gunk. Pushed a coat hanger thru and out drained the water I was looking for.
Thanks so much, this is the best site.....
Ayuh,..... Ya Gotta poke, 'n prod the drain holes in the block, 'n manifolds,....
My motor has a 3" ssteel deckscrew that lives on the intake manifold, just for that reason,....
My toolbox has another one for other boats I winterize,....
It's also why I Hate any sorta "Drain System", other than a plain ole brass pipe plug,....
The various Drain Systems Merc has used over the years amount to frozen busted blocks, just waitin' for the stars to align,.... :rolleyes:
Air don't freeze, but ya gotta get the water Out,....
