There was a service bulletin about the tell tale hose....... make sure it is routed the right way. It should be in a big loop due to the cooling issues on the 3 cylinders. Google it.
The reason for the bulletin was that the original tell tale tap into the block was not at the top of the water jacket which caused an air pocket and hence a cooling issue.
