New guy here... I just recently bought a used High Five prop for my boat. I have a 2006 4.3L Mercruiser that has an aluminum prop on it. I got the High Five to my house, took the current prop off the outdrive and that's when I saw that the High Five was totally different where the prop connects to the shaft. I know that my Mercruiser uses the Flo Torq hub kit and I am wondering if the High Five prop I bought has some other sort of hub kit inside of it that is removeable.
It does fit on the prop shaft as the grooves on the prop shaft fit into the grooves on the prop.
The serial number on the High five is 48-815760-21, the other side says 18
Thanks in advance!
Thanks in advance!
