Can vro pump be used 50:1
dsujen
i have a j90tlcur 90hp johnson. Can the vro pump be used with mixed gas if I remove the oil line? Or do I need to buy a non vro pump?
boobie
Pull the oil line off of the vro and put a cap on the fitting. Disconnect the wires coming from the vro and the oil tank and should be good to go. Don't forget to mix your gas.
