Can water get in motor oil from not being used?
digitaldav
I had my OMC Cobra 5.0 winterized. The motor oil was milky brown. This boat was sitting all year without a cover on in the elements. Could water or condensation get in the motor and cause this condition? Or am I just wishfull thinking? :) <br />If so where should I start looking? :confused:
Trent
Re: Can water get in motor oil from not being used?
Iv seen a couple of times where water dripped onto the flame arrestor and then dripped down the carb. This in turn got the oil milky with water.
digitaldav
Trent, That's nice to here. Since I just had winterized I quess there is nothing to do but wait until next year and run it.
flashback
dave, you can check with trent, but I would change the oil now. and run the engine up to temp with the new oil, then drain it and change the oil again......just a thought
Trent
As Flashback said, Change the oil now. Get that water out.
Capt Ken
Oil doesn't get milky from sitting. It has to run to mix the water with the oil so water was in the oil before the last time you ran the engine. Get the oil out and will probably take several changes to get it clean again. If the milky oil comes back, you probably have a riser leaking water back thru the exhaust. To check this, after running the engine, let it sit over nite and pull the sparkplugs. Roll the engine over and see which cylinder water shoots out of.
digitaldav
The oil is out. This was discovered when winterized.(oil changed) then. They ran 2 extra qrts. through engine to clean all water out.<br /><br />Ken, These trouble shooting test you wrote about,<br />can I do this since it was just winterized?
digitaldav
Compression Results:<br />Engine was not warm & throttle was not wide open<br /><br />#1 = 135<br />#3 = 152<br />#5 = 135<br />#7 = 165<br /><br />#2 = 180<br />#4 = 165<br />#6 = 175<br />#8 = 182
