I have a 1995 5.0 FL volvo/sx "HU" engine. For the past six years that I have had it, it often will not react to the "start" position with the ingition key. No starter turning or relay clicking, just the insturments working with about 9 volts showing. Trusted mechanics have looked at this and found nothing wrong.
However for the first time this weekend, after several hours at anchor, turning the key to start caused the engine to very rapidly turn over (it almost sounded like it was running) but releasing the key to "run" position the engine would not run. We found that the purple run wires were off the ignition switch. When I put the wires back on the engine would again not turn over. I got the engine to start by removing the purple wires, turning to the start position and then quickly attaching the purple wires.
Bottom line; with the purple "run" wires attached, the starter will not turn but the engine will run once started....with the pruple wires removed the starter will easliy turn the engine but it will not stay running.
After six years of frustration I would greatly appreciate your help in finally removing this gremlin.
