can you add a tiller arm to a outboard?
bluebrownie
looking at electric start johnson 25 hp... no tiller... off a boat with steering...can you add a tiller arm to these motors?
Jlawsen
Re: can you add a tiller arm to a outboard?
Yes, if the parts are still available you can. If it's not available as a kit, it can be costly depending on how elaborate it is.
kodibass
If you can get a donor motor of the same year & HP its not a real hard job, I have found its easier to replace the whole transom bracket and tiller as an assembly. Not near as hard as it sounds.
F_R
Actually, you haven't given us any information. What year is the motor? Did it come from the factory as electric start, or was it added as a kit? These things make a big difference in the answer. It can be simple bolt-on job, or it can require replacing major parts.
