Re: Can you manually lift/tilt an outboard? 125HP
Look right under the front of your cowling, between the transom brackets, for a toggle of some sort. When you lowered the motor you probably engaged the lock, if it has one. If you see a toggle or handle, flip it over and see if that disengages your lock. If it doesn't work, sometimes the linkage gets broken or stretched, find the stop bar that's between the lower transom brackets (it usually is a 3/8" or so bar, bent 90 on one end and a T bar of some kind on the other and there's 4 or 5 hole sets it can be adjusted in). Look for a spring loaded dog assy that is latched over the stop bar. You should be able to lift the dog off the bar with a finger and pull the lower unit aft (might need a buddy) far enough to clear the stop bar.
