jackrabbit66
- Joined
- Sep 26, 2014
- 58
97 Seasport 19' dual console
Background:
I bought my boat a few years ago knowing it had some soft spots in the deck. It turns out that the deck is made of 3/4" OSB instead of plywood. The rest of the boat seems to be well made and the stringers are all in good shape, from what i can see. under the OSB is a 1/32" layer of glass and resin however the deck is a 1/8" fiberglass shell like the hull and frame of the boat. The OSB is pretty much a water logged sponge at this point & can be scraped off the fiberglass & deck with a spoon in some spots & in others i can remove the OSB with an oscillating saw.
Theory: I would like to lay in new marine grade plywood, saturated with resin, fiberglassed seams & edges. once the plywood is in place I would use some kind of adhesive to "glue" the old 1/8" fiberglass shell to the new plywood deck.
Reason: The fiberglass shell is 1/8" thick which provides a protective barrier from water & other damage & it just looks good.
Possible flaws to plan: I'm worried that unless the fiberglass shell is completely "laminated to the plywood deck that water is going to find its way in and cause problems.
Question: If i can remove the 1/8" deck from the osb.... CAN I RE-USE the 1/8" molded Fiberglass decking over new plywood?
Thanks!
Background:
Thanks!
